Old 08-05-2015, 08:41 PM   #13 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by oldtamiyaphile View Post
Although the mechanism differs from petrol, diesels main party trick is changing AFR to suit load conditions. A diesel can run 100:1 at idle and 14:1 under load. If diesels always ran lean, they wouldn't make smoke under heavy load - even the latest BMW will put out visible smoke if driven hard.
Sure, I see plenty of overpowered diesel pickups that smoke like trains, but that's because they've chipped them to make more power by adding fuel. But in a factory setup, it's difficult to make them smoke because they are designed to be clean. Volkswagens are some of the cleanest around. When I get mine emissions tested (at load), it regularly turns less than 6% opacity. They are designed to run lean of stoichiometric.
I'm not coasting, I'm shifting slowly.
