Old 08-05-2015, 07:45 PM   #11 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by UFO View Post
Diesel engines do not regulate AFR, there is no throttle. As long as the turbo supplies enough air, the AFR will be lean under all load conditions.
Although the mechanism differs from petrol, diesels main party trick is changing AFR to suit load conditions. A diesel can run 100:1 at idle and 14:1 under load. If diesels always ran lean, they wouldn't make smoke under heavy load - even the latest BMW will put out visible smoke if driven hard.
Old 08-05-2015, 07:55 PM   #12 (permalink)
Team Turbocharged!
Pickups
Originally Posted by elhigh View Post
That's an awful lot of mass to tow around with a 1.2. I reckon once it gets up to speed it isn't too bad though. God knows the TDI engines make good torque for their size, if you have the time I don't doubt it'll accelerate up to highway speed eventually.
Renault is one of the first in modern times to go to a really small engine for a really big car, in the Trafic, you get 1.6 litres to move a 1700kg van. It still does 0-62 in 10.8 seconds (still faster than some hatchbacks), and is rated for a total train weight of 5 tons
Looking at Vekke's figures, his car has the same power for less weight and a better frontal area. I thought the first tank was a disappointment, but the second tank shows promise. I'd have hated all that work to have gone to waste. But it looks like a 'fast enough' car that will do 60mpg now
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
renault_megane_dci (08-06-2015)
Old 08-05-2015, 08:41 PM   #13 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Sure, I see plenty of overpowered diesel pickups that smoke like trains, but that's because they've chipped them to make more power by adding fuel. But in a factory setup, it's difficult to make them smoke because they are designed to be clean. Volkswagens are some of the cleanest around. When I get mine emissions tested (at load), it regularly turns less than 6% opacity. They are designed to run lean of stoichiometric.
I'm not coasting, I'm shifting slowly.
Old 08-05-2015, 11:41 PM   #14 (permalink)
So, what are you considering to do in order to overcome the smoke issue?
Old 08-06-2015, 12:21 AM   #15 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Its just a matter of ecu tuning in my case. ecu tries to get more boost even its not capaple to deliver so it injects more fuel. The Turbos vnt control is not fully in use due to program is for smaller turbo whichs boost peaked a lot so its not closing totally the vanes in current program.
There are 3 "programs" in depending on my gas pedal position.
0-70% is at the moment very efficient but no boost is the 2 liter fuel consumption range. 70-90% is efficient acceleration with 0.8-1 bar boost
90-100% is flat out acceleration (all in) with 1.5-1.7 bar boost
at the moment the car goes on to that 90-100% range on bigger uphills and gives smoke.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 08-06-2015, 08:39 AM   #16 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
If I remember right from my mark 4 VW days the 1749 was an up sized turbo for those 1.9 liter TDI and even in factory form they would go just fine with 90 hp and 177 Ft/Lbs.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 08-06-2015, 09:14 AM   #17 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Got the vehicle weight down to under 1500k - WOW. That's a lot of dieting!
I don't think I had accurate numbers to look at for the 1.2's output. If it's going as well as all that, I think the numbers I saw were either old or just flat wrong.
Old 08-06-2015, 09:47 AM   #18 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
I let the large size of that car distract me from the fact that it is an aluminum monocoque platform. Its very light for its size! There is even a picture of one with polished aluminum--no paint.
Old 08-06-2015, 02:39 PM   #19 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Today tested acceration and result was 10.5 seconds average for 60-120 km/h acceleration.
Weighted the car in corner weigth scales and resuts were:
Front Left....Front Right
420............430kg
Rear Left......Rear Right
300 kg..........320kg (12V battery is in this corner.)
Total 1470 kg with full tank in this measurement.
Old 08-06-2015, 04:04 PM   #20 (permalink)
UFO
UFO's Avatar
That's not bad for a big car. 3240 US pounds for the metric-challenged.
The Following User Says Thank You to UFO For This Useful Post:
Xist (08-07-2015)
1.2tdi, audi a8
