Old 07-29-2008, 09:20 PM   #3 (permalink)
azraelswrd
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
An A/C unit will need to dump the heat somewhere... which makes me think it won't be as helpful as it can in such an enclosed space as a car. If humidity is a problem, I'd use the in-car A/C sparingly. Otherwise if humidity is low, a portable fan that uses less power/generates less heat would be my option.
But then again, you look like you're doing pretty well on MPGs. A little AC and/or window crack wouldn't hurt in small doses.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
