Old 08-08-2015, 10:23 AM   #43 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If it's actually too cold on your butt, use what nature uses in the bloodstream to your hands and feet ...
A heat exchanger between the cold flow and the returning warm flow
This will
- warm up the cold stream going to your butt ; the size and efficiency of the heat exchanger will determine your butt temperature
- cool down the return flow, reducing the melting rate of the ice
Remember, cooling is more efficient (or as here: too efficient) as the temperature difference is higher
By increasing (!) the coolant temp @ your butt to a more comfortable level, you'll actually increase the time the system can keep you cool ...
