Old 08-09-2015, 04:32 PM   #113 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Old Mechanic View Post
A little over 4400 miles now, first service will be 8/20 at the selling dealership. Only issue has been right rear wheel alignment which will be checked at the first service to document the issue.
Running flawlessly, no other issues other than right rear wheel.
Lifetime mileage since new, including the 15 miles on the odometer when I took delivery is 54.3 mpg, with instrumentation reading 55.5 ( pretty close but still optimistic).
It uses the same oil filter as my 1gen Insight, so I have an additional spare oil filter.
Last refill was @ $2.149 and 56.01 mpg, LESS THAN 4 CENTS A MILE.
regards
mech
That's awesome!!!
At .03x cents a mile aren't your getting around the same as a EV cost per mile???
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
user removed (08-09-2015)
