I'm again bringing an old topic up. Anyone heard any updates on this? Has any of you heard these tires being used or tested?
The 155/70R19 tires seem to go for around 100€ each when new and used i3 wheels and tires are getting more and more available. But the 155/70R19 tires are reported quite heavy, their weight is 16.37 lbs (7 kg), with rim that weigh will probably be way over 30 lbs. I found a internet blog stating that 155/70R19 winter tires with i3 optional rim are 36 lbs.
The BMW i3 has 5x120 bolt pattern.
