Old 08-13-2015, 12:10 AM   #117 (permalink)
Hockeynut
Hockeynut's Avatar
Ready to roll the lil Mits to work and the tire light was on...Luckily this happened at home and was able to plug it and pump er up then on my way...Late for work the first time in 8 yrs..
Got me thinkin if this would have happened on the interstate rather than the driveway I would have been relegated to changing the tire...Not a fan of an oddball donut on the car so I just purchased a factory 14" Aluminum ES wheel...It appears the space the current donut is in will have enough room to fit a factory wheel and tire....Keep ya informed Old Mechanic incase you or any other Mits owners want a reg size wheel and tire...BTW the spare is a 14" steel wheel so maybe just swapping over to a reg size tire and reusing the spare steel wheel is another option.
On a side note.My last tank averaged 49.6mpg...Have now racked up 23,580 miles and still tight,quiet and smooth.
2014 Mitsubishi Mirage--Sadly in Mits graveyard along with the deer.
2017 Chevy Spark
The Following User Says Thank You to Hockeynut For This Useful Post:
MetroMPG (08-13-2015)
