Old 08-13-2015, 05:52 PM   #38 (permalink)
bikeprof
Wannabe hyper..., miler !
bikeprof's Avatar
White Variant - '96 Volkswagen Passat TDI ~ GLS- 4 Cyl
Minivan - '96 Chrysler handicap IMS built LXI
Insight - '10 Honda Insight EX
Originally Posted by 320touring View Post
Looked at the Konis- 4 of them would be 2x the cost of the car, whereas 4 Billies will be 75% of car cost.
thanks for tips re turbos- need to get a good looka t the car to make sure its worth spending the money on.
also need to decide if I'm doing the timing belt
TIMING BELT ? That is a HAVE TO...
Unless the previous owners are your family and YOU took the car to mechanic, DO THE TIMING BELT ! Otherwise the cost of the R & R would be 5-6 the value of your car, just for the engine + labor
PS. I have the KONI and they ARE worth the extra money. Would someone around you have a VW with KONI's ? See if you can drive or be in it, you'll feel the difference :-)
