Old 08-14-2015, 05:54 PM   #298 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Whats the deal with running leaner than 17:1?
When I start to get up near 18:1 I can tell power is dropping off pretty bad.
Is that normal or am I not running enough timing advance?
On my engine I try to run at least 18:1 and up to 25:1 depending on load. I'm trying to run lean enough to reduce all intake pumping losses. The turbo helps with this verses a N/A engine.
I'm also increasing ignition timing to help out the lean burns slow flame propagation.
Pressure Gradient Force
The Positive Side of the Number Line
