Old 08-18-2015, 10:09 AM   #22 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Originally Posted by Cycle View Post
I kind of ran into a road-block in my plans... Baisley Hi-Performance says their rollers are all too large and heavy (they're for Harley-Davidson motorcycles, after all), so I've got to find a fabricator who can chop up a pair of existing flat tappet lifters and put rollers on them... the rollers will actually be ceramic bearings, so all they really need to do is replace the flat tappet with an axle on which to mount the bearing. Haven't found anyone yet.
IIRC, the rollers were expected to widstand agressive cam profiles, right ?
If it's about friction, you could have the pads friction coated.
That particular part of your project is the one that sounds the most expensive to me and the one with the least ROI in terms of FE.
Huge CR + water injection or Atkinsoning (delaying inlet closure to 105 ATDC as in the Prius) the engine sounds more rewarding FE Wise.
