Originally Posted by UltArc
For me, and for most vehicles I believe, a kill switch just stops the engine and the things the engine directly powers, the vehicle continues the functions that occur while in the ON position and running.
From what I red here and there, you want to kill the engine with the ECU still working and that means it is not the same as turning the key (or hitting the OFF switch).
As it is not hat common a car for ecomodding, you are in un-charted territory :/
