Old 08-19-2015, 08:50 PM   #9 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by sendler View Post
Those won't be bright enough. You would need the 22 Watt LED's with the cooling fan instead of the heatsink. But then the cooling fan doesn't fit within the closing cap of many headlight housings. The area of the light source is also much greater than a halogen or HID so the beam pattern probably lacks focus.
I always want more light on all my vehicles. Not less.
Scott,
Thanks. I agree the beam pattern can't be right, as the two LED chips per "bulb" are each larger than the longitudinal (aka axial) filament in the 9006 standard bulb. But I think I can live with it as long as the pattern is better than the do-it-yourself cheapie HID conversions that glare in my eyes every day.
As for brightness - did you note there are two chips per bulb? One on each side of the stick. They claim 2500 lumens/bulb, vs 1000 per halogen bulb. Do you think they're stretching the truth a whole lot? I know that's been done in the past.
Coast long and prosper.
