Originally Posted by RedDevil
I already have a wing shaped sleeve over my car's antenna stalk, but it is a bit out of shape.
I'll use this as a template to craft a new one from hard foam and thick alu foil.
Thanks again for your post. you reminded me my truck has two aftermarket antennas in addition to the standard antenna.
I'd like to keep the CB radio, but the one on the roof is no longer in use and of course is the hardest to remove.
I can make some sleeves though.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
