Old 08-22-2015, 06:34 PM   #60 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
either that or black plastidip with clear, which comes out satin. thanks.
**EDIT**
cut out 4 new blanks from the same stainless material. reason being, stainless is EXTREMELY hard to drill through. so i used the welder. which made the hole too big. so i welded a washer to the inside. this caused warping. hence the dents from a BFH.
so, i will cut 4 more discs, will use a lot of cooling fluid and use the drill. my drill press is too small so it'll be by hand.
will try to point one of of the punches and punch a hole in a piece of scrap first but can already see it not going well. will use a wooden backer for the process.
enough of that....
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
