Old 07-19-2015, 12:07 AM   #51 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
RIP, moon eye... how we loved ye.
deejaaa (07-19-2015)
Old 07-19-2015, 11:43 AM   #52 (permalink)
What's the circle in the middle? Any chance it was bearing on the end of the axle?
I have a set of baby Moon/Speedster hubcaps that will snap onto the front wheels, but won't on the rear because the rear axle sticks out about 1/4" too far.
Maybe that's why they let loose.
Old 07-19-2015, 04:38 PM   #53 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
it's just dust. there is a lot of offset on the wheels. probably 6 inches between wheel and cover.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 08-15-2015, 09:11 PM   #54 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
After three months I decided it was time to check my tyre pressures. I was surprised at how hard it was to get my disks off I added 3PSI and popped them back on. So it seems you get what you pay for, genuine Moon's seem to stay put
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
aerohead (08-17-2015), freebeard (08-16-2015)
Old 08-20-2015, 09:16 PM   #55 (permalink)
Not banned yet
deejaaa's Avatar
i might miss the 'ol mooneye, but, i have a replacement.
all parts i had on hand so material cost: $0.00.
1-8th stainless sheet stepped up to offer some material for the attachment:
discs were cut out a while ago:
basic shape:
centers located:
cinched down, tight fit and rigid due to the bends. screw welded in center:
used welder on high to burn a center hole. welded stainless washer to hole on inside. warped some so beat it out.
there is no bulge. it sits flat against rim lip and brace i added.
nut was a stainless wingnut, removed wings so need pliers to remove:
just hope it's balanced. everything was measured by eye ball, no measuring device. took about an hour to get it fitted because the disc was waiting already.
The Following 2 Users Say Thank You to deejaaa For This Useful Post:
aerohead (08-22-2015), BamZipPow (08-22-2015)
Old 08-21-2015, 03:01 AM   #56 (permalink)
It's too bad you couldn't leave the wings on. Vandalism, I suppose.
Old 08-21-2015, 09:34 PM   #57 (permalink)
Not banned yet
deejaaa's Avatar
here's a shot in the daylight:
Old 08-22-2015, 12:25 PM   #58 (permalink)
I'd polish those stainless badboys to a mirror finish and replace the cut down ex-wing nut with a good nyloc locknut, carry the correct wrench for them in the glovebox.
Old 08-22-2015, 04:41 PM   #59 (permalink)
Polishing would show up every dimple and wave when they're rotating. I'd go with a satin finish.
deejaaa (08-22-2015)
Old 08-22-2015, 06:34 PM   #60 (permalink)
Not banned yet
deejaaa's Avatar
either that or black plastidip with clear, which comes out satin. thanks.
**EDIT**
cut out 4 new blanks from the same stainless material. reason being, stainless is EXTREMELY hard to drill through. so i used the welder. which made the hole too big. so i welded a washer to the inside. this caused warping. hence the dents from a BFH.
so, i will cut 4 more discs, will use a lot of cooling fluid and use the drill. my drill press is too small so it'll be by hand.
will try to point one of of the punches and punch a hole in a piece of scrap first but can already see it not going well. will use a wooden backer for the process.
enough of that....
