Old 08-23-2015, 02:06 PM   #62 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Punching through 1/8th inch steel would require a backing die to get a shearing action. But you've probably just figured that out.
What kind of a welder made the hole too big? If it is oxy-acetylene a smaller tip might help.
I haven't tried it yet. need some cut-off wheels that i'll get on the way home to finish cutting the blanks.
MIG is what I used. steel wire. always was told in order to weld steel to stainless, an SS rod was needed but I have welded the 2 just fine using steel wire and gas. weird how the pool of molten metal jumped across the steel table I had it on. stayed a big ball until it hit the floor. left a trail of soot where it touched.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
