Old 08-24-2015, 10:00 AM   #310 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by serialk11r View Post
Stainless steel fuel lines or whatever people use for methanol fuel is probably a good idea. Toluene and acetone at high concentrations is probably bad for the fuel lines. I think it's not very much money, if you're burning solvent for free the fuel savings should add up pretty quickly.
This is a concern for me. On my Talon everything was set up for methanol, so its good to go. On the Insight I need to look over the fuel system.
Pressure Gradient Force
The Positive Side of the Number Line
