Finally got the trailer jack mount built! Changing the tire on the road just got easier...
I happened to guess the correct amount of clearance needed fer the wheel pant and Dark Aero's side panels.
Just enough clearance from the front edge...
If I trim the upper tail portion of the wheel pant down a little more, it should be able to clear the belly pan once I start designing the new pan.
