Old 08-24-2015, 09:11 PM   #621 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
so far so good.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
BamZipPow (08-25-2015)
Old 08-25-2015, 12:47 AM   #622 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Making some measurements...width of the fork is 6.5" wide, 8.75" fer the axle.
With an ideal ratio of 3.93:1, this would mean the length of the wheel pant should be around 25.545" fer a width of 6.5" and a length of 34.3875" fer a width of 8.75". I should be able to easily fit that under Dark Aero with ease.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (08-25-2015)
Old 08-25-2015, 10:42 AM   #623 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
A quick and simple mock up with cardboard. The cardboard piece is 31" long and the front edge sits right at the vertical pivot point. The back end of the wheel pant extends 9" past the rear of Dark Aero.
I will have to taper trim the rear portion so it will clear the bottom of the sides and rear while articulating. I will have to taper the bottom edge to clear driveways and speed bumps. The rear part will be fully enclosed. The nose cone will be a separate attachment piece. There will be attachment brackets fer the wheel pant to easily bolt on to. I will be using the data I learned from the previous attempts/tail cone setup fer clearance. I might even apply a skid plate fer the bottom, too!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (08-25-2015), deejaaa (08-25-2015)
Old 08-26-2015, 03:36 PM   #624 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Removed the rear end pieces to make room fer the wheel pant clearance as well as room fer the jack adapter block.
The wheel pant frame is in place and the cardboard mock up is starting to take shape. I shouldn't have to worry about the wheel pant making any sort of contact with the tire. The tapered part will be fully enclosed.
aerohead (08-26-2015), deejaaa (08-26-2015)
Old 08-27-2015, 10:05 AM   #625 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Found this old thread from about 5 years ago. Guess I'm the only one going through with the process.
http://ecomodder.com/forum/showthrea...mod-11973.html
Old 08-27-2015, 12:30 PM   #626 (permalink)
Not banned yet
deejaaa's Avatar
interesting comments. my favorite:
Originally Posted by winkosmosis View Post
I think it's pointless to make a boattail that's heavy enough to need a wheel holding it up
BamZipPow (08-27-2015)
Old 08-27-2015, 01:19 PM   #627 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Finally got the trailer jack mount built! Changing the tire on the road just got easier...
I happened to guess the correct amount of clearance needed fer the wheel pant and Dark Aero's side panels.
Just enough clearance from the front edge...
If I trim the upper tail portion of the wheel pant down a little more, it should be able to clear the belly pan once I start designing the new pan.
Old 08-27-2015, 01:46 PM   #628 (permalink)
Dark Egg - '12 VW Touraeg
https://missoula.craigslist.org/rvs/5192552513.html
I saw this 1957 single wheel camper on our local Craigslist. I think $3000 is a little steep but supposedly it's very nice.
The Following User Says Thank You to Hersbird For This Useful Post:
Old 08-27-2015, 02:47 PM   #629 (permalink)
Not banned yet
deejaaa's Avatar
that was mentioned a few times but i think it's also because of the "costume tow bar". can't say i've ever seen one of those but it must be nice also.
Old 08-28-2015, 12:30 AM   #630 (permalink)
The pictures were terrible as well. The best Craigslist ads are the ones with spelling errors and bad pictures. Usually that means a $300 price tag not $3000.
BamZipPow (08-28-2015)
