Old 08-29-2015, 05:54 PM   #125 (permalink)
slogfilet
VX Padawan
VX du Slog - '94 Honda Civic VX
Finally installed an air dam! No testing yet, but we'll see if there's any difference to my very consistent commute.
This is attached in place of the stock VX front lip. I just used 6mm bolts and 1.5"x1.5" L-brackets (drilled out slightly to accommodate the bolts). Then stainless steel bolts, washers, and nuts to attach the lawn edging to the brackets.
The Following User Says Thank You to slogfilet For This Useful Post:
TDFbound (11-25-2018)
