Only the injector pump is mechanical now.
The fuel pump, coolant pump are electric now. Other electric loads I have that will only run occasionally is that little ARB air compressor it only draws like 10 amps a shut off pressure, some more lights. Other goodies I have in my possession, but not installed yet are a Gast air compressor that takes 50 amps just to free spin it (it is a starter motor with 2 air compressors on it) and a Xantrex 1000 watt pure sine wave inverter.
Then also 98 inch by 18 foot deck tandem axle trailer with 4 electric brake hubs plus its light (my trailers lights are full LED already)
Other devices I need to acquire are a vacuum pump to operate the hvac controls and an LED light bar.
When I need the alternator, I really need the alternator to produce.
I already have solar panels, a left over from when I had lead acid batteries. Only about 20 watts worth. But it could bring the lead acid batteries up to 13.4 volts on a freezing cold day as long as the sun was out.
I want to go from 15 to 20 watts to more like at least 70. There are a lot of really cool flat flexible panels out there now compared to even just 2 or 3 years ago.
But that's a whole nother post.
The glow plugs are needed pretty much any time the engine coolant temperature is below 120'F or it just wont start, or I will have to crank it several seconds longer to get it to fire.
If I know it will fire with out using the glow plugs I don't use them, saves the battery, relay and glow plugs.
If I can get the belt holding guards just right when the alternator belt goes loose it should only be touching the guard, the alt pulley and be sitting just above the crank pulley not touching it at all.
