Old 08-30-2015, 11:48 AM   #8 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I did some research and it looks like chances are that this isn't strictly legal. With that said, I consider it unlikely that it would be a problem. Once I have the money to afford a citation for improper headlamps, I'd likely do the conversion since my headlamp lenses are cataract yellow due to UV.
I may just polish my headlight lenses though. If I was to do all around LED retro, I'd have to disable my idle up valve to see most of the FE gains (on my car, the idle up valve is ran off of the tail lights).
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
