Old 09-01-2015, 01:58 AM   #15 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
I have to look at suspension travel. If there is enough clearance I could place the pivot point almost at the middle of the tire up inside the fender, and use a similar roller system to push the fairing out fore or aft of center as needed. Install a small cylinder fore and aft in a closed hydraulic loop to make a three point suspension on the fairing, with some sort of detent to keep it centered at high speed.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
aerohead (09-01-2015)
