Good news - I got everything hooked up as far as getting the car into lean burn!
Bad news - When I flip the switch, nothing happens
It appears like I may have tapped into the wrong wire. I need to hook up to the MAF -> PCM wire and bleed voltage of off it, while I believe I did PCM -> MAF. That ain't going to work!
I'll upload pics of the completed job and results when life gives me the chance... The car is still averaging 50-51 mpg even without LB
