Originally Posted by oldtamiyaphile
Weight is the enemy of endurance. A brick dropped from a height will break into a million pieces that a block of styrofoam will survive (even in a vacuum).
What does weight have to do with safety? And I find it hard to believe a 5 pound brick dropped from 10 feet will survive better than a 6 pound Styrofoam block dropped at the same height.
Originally Posted by Frank Lee
https://wausau.craigslist.org/mcy/5137421194.html
MotoTec Solar Electric Go Kart 24v Red - $200 (plover)
fuel: electric
transmission: automatic
safety tips
prohibited items
product recalls
avoiding scams
Scratch and dent
The MotoTec Solar Electric Go Kart provides up to a 2 hour ride time with its integrated 4watt monocrystalline silicon solar panel on the rear wing that continuously recharges the go kart while in use. It's powered by a 16Ah 24v battery pack and 350 Watt DC motor that can reach speeds of 15mph. The solar panel can also charge the go kart while not in use or with the battery charger in 4-6 hours. This go kart comes standard with 9 inch pneumatic tires for a variety of terrain and easy to use disc brakes.
Motor: 350 Watt DC Electric Motor
Top Speed: 15 MPH
Battery: One 24v 16AH Lead Acid
Solar Panel: Integrated 4W Monocrystal Silicon (13x9 inch panel)
Battery Charger: Included
Ride Time: 2 Hours (compared to 45min)
Frame: Steel
Rims: Aluminum 2 piece
Tires: 9 inch Pneumatic (9x3.5-4)
Brakes: Rear disc with hand lever
Green: Zero Emissions
Recommended Age: 13+
Max Rider Weight: 150 lbs
Product Dimensions: 48x33x21 inches
Product Weight: 80 lbs
Box Dimensions: 49x35x15
Box Weight: 103 lbs
Bullcrap.
