Old 09-04-2015, 09:11 PM   #320 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Ardent View Post
Thanks for the good explanation and answer.
By what are you gaging zero pumping losses?
Going off my MAP sensor reading of 0 vacuum to 6 psi of boost. Also data logging exhaust back pressure. Running a + engine delta p.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Ardent (09-04-2015)
