Old 09-06-2015, 12:48 PM   #18 (permalink)
freebeard
The Dymaxion would be a better example to follow than say the Campagna Motors T-Rex because it has a lot more internal volume; important when you scale it down to your size. It's being discussed right now in another thread:
The question to be answered by my following aerohead's dimensions would be the difference between a pointed tail like The Template and a rounded tail like the Dymaxion.
I've been struggling with an English translation of Kamm's research and what I can say is, 'don't do 'rounded' truncations.Make the cut as if you'd do it with a bread knife.Straight chop.
There's your opportunity for taillights and license plate. They both have a wide track to compensate for zero track in the rear.
Here's my own design for a(n un-truncated) Dymaxion clone:
It's advantage would be the mathematically defined shape lends itself to formless construction. Since it is malleable it could provide a narrow body for a two-wheeler as well.
HHOTDI (01-16-2019), Rooivalk1 (09-06-2015)
