Old 09-06-2015, 03:17 PM   #19 (permalink)
Rooivalk1
Rooivalk1's Avatar
The Dymaxion would be a better example to follow than say the Campagna Motors T-Rex because it has a lot more internal volume; important when you scale it down to your size. It's being discussed right now in another thread:
There's your opportunity for taillights and license plate. They both have a wide track to compensate for zero track in the rear.
Here's my own design for a(n un-truncated) Dymaxion clone:
It's advantage would be the mathematically defined shape lends itself to formless construction. Since it is malleable it could provide a narrow body for a two-wheeler as well.
Thanks, most of the designs you'll see in the links I left in my second comment in this thread are straight chops for this reason, It would allow for taillights and a numberplate, without drastically affecting airflow like a curve would. I'd have to say my favourite design of mine so far is this one, because it has good visibility and crosswinds shouldn't be a huge problem, as well as the numberplate thing: The rest of the fairings 4 September - Album on Imgur
