Old 09-09-2015, 02:20 AM   #64 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
You should check out my thread on the G1 Insight. I've had basically every issue stereotypical of the car, and nearly all of them were quick and simple fixes.
http://ecomodder.com/forum/showthrea...ild-29288.html
Lean burn took me a while to figure out, but here's my basic understanding of it:
In 5th gear, accelerating with 100% load, you're at 45-50mpg. If you let off the pedal gradually until you reach ~100mpg, after a moment the car will drop into lean burn and shoot up past 150. You can then press the pedal back in to around 75mpg. Anything beyond this and you're at ~100% load again and it will drop out of lean burn and begin electric assist.
pgfpro (09-09-2015)
