Old 09-09-2015, 11:28 AM   #16 (permalink)
Daox
The yellow us UV damaged plastic. You need to remove that layer to clear them up. Then, you really should add a layer of UV resistant coating on top of it to lengthen the amount of time until it yellows again.
Here is my write up on my headlight restoration. Its holding up pretty well.
http://ecomodder.com/forum/showthrea...-uv-30237.html
The Following 2 Users Say Thank You to Daox For This Useful Post:
deejaaa (09-09-2015), RedDevil (09-09-2015)
