Originally Posted by bobsright
......what do you do for two weeks to a month waiting on a replacement? good point.
Not sure I even understand the logic involved running lights off a dedicated battery. Does the gained mpg offset the lost mpg from added weight, also how about the lost space? weight and space are the same, it's still a battery. How do you charge these batteries? at home on a charger. What is the cost of the electricity for that? pennies. If you rigged up something to where the engine charges them, then isn't that the same electricity that would go directly to the lights? nothing charges them while driving. Maybe I'm missing something. i should say so. Explain please?
i'll try to not be critical of your questions but you should read more. this is a hobby and we enjoy what we do. have a little more fun with your life and enjoy it better, and read some more, after using search.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
