Old 09-09-2015, 01:46 PM   #17 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
The yellow us UV damaged plastic. You need to remove that layer to clear them up. Then, you really should add a layer of UV resistant coating on top of it to lengthen the amount of time until it yellows again.
Here is my write up on my headlight restoration. Its holding up pretty well.
http://ecomodder.com/forum/showthrea...-uv-30237.html
you said it better than me. there is no UV coating from the factory.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
RedDevil (09-09-2015)
