Old 09-09-2015, 05:19 PM   #292 (permalink)
pearl62
Here's a spreadsheet I have put together to try to compare all the different commonly available cells and come up with a solution. Just adjust the green values on the first sheet, and the numbers will update on the second sheet to reflect the necessary cells needed for your requirements. I add more rows with parameters as I need them and more columns as I find different cells. The pricing may not be the latest for some of them, but it's close, and your own purchase power might differ from mine...
The conditional formatting was for my own needs, but you can change those for yours.
I hope this helps.
The Following User Says Thank You to pearl62 For This Useful Post:
e*clipse (09-09-2015)
