Old 09-10-2015, 08:23 AM   #68 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by pgfpro View Post
Have you done anything with index the spark plugs? I have some left over index washers that would work and I'm thinking about trying them. Thoughts?
The Insight has indexed plugs already. Next to the hole where the plug screws into, there's a letter stamped on the block, and you need a matching plug for that hole (there are 4 variants of the plug). They have a tendency to back out over time, which un-indexes them, of course. Torqued to spec, the plug faces intake valve #1 and helps when running extremely lean.
pgfpro (09-10-2015)
