how do i locate my speed sensor wire and injector wire?
hi
i don't think my vauxhall corsa has OBD2. i couldn't find it so i am planning on installing the mpguino. i have ordered a haynes manual for my car so hopefully that will shed some light.
is there an easy way to find the wires -can you trace them from the ECU or spedometer/injectors? is there a standardized colour scheme? can your multimeter help you?
there are loads of wires in a big bundle around the steering wheel, how do i know which ones?
im pretty confident i can put together the mpguino but its the vehicle interface bit which worries me!
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
