Keep your interior fan speed near high when its hot and you need AC. If you have a button to turn on the AC you can turn it on as you are coasting down hill or slowing for a traffic light like a jake brake. When you turn off the AC the fan will still blow cool air for a while after. I've been very satisfied with the ride quality with my stock tires aired up to 50psi. The max is listed at 44. Other tires would be too harsh and these tires are only a year or two old. I wouldn't recommend this on old tires but there is benefits beyond 55 psi if you're willing. Tire pressure and AC use where some of the biggest helps when paired with what you're doing already.
