Old 09-14-2015, 02:07 PM   #259 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Russell, the LTFT are at +16-17% while in lean burn. When the switch is turned off, they go back down to +11%. This is about right since I am running 17 lb. EV6 injectors in place of stock 19 lb. EV1s (11.76% difference).
The STFT are maxed at +32% when in LB. As soon as the switch is turned off, the numbers crash down to -4% - +5%.
Originally Posted by whatmaycome14 View Post
I think I'm missing the detailed information about what you're doing to achieve LB. I understand the idea of tricking the computer into thinking there is less air than actual going into the engine, but I don't read HOW you're doing this. How exactly are you "bleeding voltage off the MAF sensor?
I'll have to draw out a diagram tonight and upload it to be absolutely clear. I have a wire connected to the MAF signal wire going into the PCM. This wire runs to a switch that is connected to a penitometer. From the penitometer, a wire runs to a main ground. When the switch is on, it allows voltage to come through the penitometer, which "divides" the voltage. It takes some of the voltage and grounds it out, but sends the rest to the PCM. The PCM sees a low MAF voltage and reduces the amount of fuel injected.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following 3 Users Say Thank You to BabyDiesel For This Useful Post:
MobilOne (11-12-2015), pgfpro (09-15-2015), whatmaycome14 (09-16-2015)
