Originally Posted by Donahue
agreed on the mirrors, I'll accept the aero penalty. I'm coasting now using the key, i can coast the last mile to my house and even with a couple of turns onto different streets, ive got enough momentum to pull into my driveway. the brakes seem to be fine when off, either there is plenty of vacuum reserve, or the vacuum assist isn't super powerful to begin with. But EPS would be nice, or maybe just removing the PS and convert to manual.
I get about three full pushes on the brake pedal before the pedal gets hard. Even then, it will still brake OK, but I typically start the engine and kill it to build up vacuum again. If you have lots of downhills where you regularly run out of vacuum, you can add a vacuum reservoir.
My power steering is disabled. I don't miss it a bit. It's a light car, I don't feel it is needed at all.
