Old 09-15-2015, 11:51 AM   #261 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
Russell, the LTFT are at +16-17% while in lean burn. When the switch is turned off, they go back down to +11%. This is about right since I am running 17 lb. EV6 injectors in place of stock 19 lb. EV1s (11.76% difference).
The STFT are maxed at +32% when in LB. As soon as the switch is turned off, the numbers crash down to -4% - +5%.
I'll have to draw out a diagram tonight and upload it to be absolutely clear. I have a wire connected to the MAF signal wire going into the PCM. This wire runs to a switch that is connected to a penitometer. From the penitometer, a wire runs to a main ground. When the switch is on, it allows voltage to come through the penitometer, which "divides" the voltage. It takes some of the voltage and grounds it out, but sends the rest to the PCM. The PCM sees a low MAF voltage and reduces the amount of fuel injected.
Sounds like LTFT has already made its adjustment to the new injectors. Also it looks like STFT is adjusting when toggled off/on so I would just do a off for about 4 to 5 seconds right before the 10 minute mark to keep PCM happy and that should let you enjoy your lean burn.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
BabyDiesel (09-15-2015), MobilOne (11-13-2015)
