Old 09-16-2015, 07:24 AM   #50 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Originally Posted by 101Volts View Post
I tried to get the roof-rack off. Didn't work. I have the proper size star bit (T25) and these bolts are on like a metal pipe in frozen ground. I'd imagine taking the rack off will aid a great deal.
I assume you have or are going to start bathing them in some sort of liquid-wrench type fluid to help if they are corrosion seized. From my construction experience, if you are putting loads of force on a T-25 bit the best quality bits you can get are the Dewalt "Impact Ready" bits, typically available at big box stores in two packs. That would help from rounding out the heads like lower quality bits sometimes will. After several treatments of antiseize and putting a good T-25 driver in a 1/4" socket in a decent ratchet/breaker bar I would think they would come loose (or shear off...).
