Old 09-17-2015, 10:11 AM   #114 (permalink)
GreenHornet
GreenHornet's Avatar
Hey CJ,
Great questions I will do my best to answer. So firstly Yes I will be using Lithium battery chemistry to power the Electric Supercharger. The ME0709 can be run at voltages from 24 to 72 Volts.
Here is the basic electric motor specs:
The ME0709 is a Brush-type Permanent Magnet DC motor. Light weight, high efficiency design. Designed for 24-72 VDC battery operated equipment. Capable of 300 amps peak and 125 amps continuous. Totally open, fan cooled motor. Similar in performance to the Perm-motor 132 and the Lemco or Lynch LEM-200 motors.
Specifications
Power: 8 cont-- 19 pk hp
Voltage: 72 Volt rated
Speed: 3700 rpm @ 72v unloaded
Size: 8" OD, 6.5" long (w/o shaft)
Shaft: 7/8"x 1-3/4", 3/16" key
Weight: 36 lbs.
