You're dealing with a standard ignition key or a push button on that year? I'd to do the injector cut on mine but I'm confounded by the push button start.
Its cool to see that the 2 responds very well to ecomods as well as the 6 and CX-5. I have a belly pan to the rear suspension but the exhaust tunnel is open. I'm leary of flashing that in for fear of reflective heat melting the sides of the belly pan where it meets the tunnel. Maybe lawn edging would work 95% as well as trying to fashion a full pan. You're getting after it, so maybe both together is best.
