Originally Posted by oldtamiyaphile
Leave the area in front of the IC open, and block the rest, you can also leave the intake side open or make a deflector into the intake. That's how I did it on my TDI.
Not my engine bay, but the same model -
http://i24.photobucket.com/albums/c4...2022010243.jpg
In stock form, the air intake runs to the side of the engine bay and opens out by one of the headlights.
I can block the upper grille without affecting the IC, and I would keep an eye on how this affects intake temps... which might not actually be too bad given it doesn't directly use the front grille.
Alternatively, I could reroute the air intake to the front grill, and do a partial block.
Which would be the better option here?
Thanks
