Old 09-26-2015, 12:57 PM   #344 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Update:
OK it looks like I have enough waste solvent now to last me clear into next Summer. So I'm thinking I might get a used Honda Generator and run it on waste solvent also and use it to run my heaters this winter in my garage.
I need make a few changes to the Talon and a lot of modifications to the Insight so heat will be a must.
I'm also going back to my single intake valve system on the Talon. I modified one of the lifters or "lash adjuster" to only open one intake valve about 1/8" off the seat and it has about 1/3 of the duration compared to stock. This helps with swirl and makes ultra lean burn work a lot better. It still has decent power though, enough to keep the car fun in the winter.
I wanted to get it to the track but I still need to purchase a new fuel regulator, bigger injectors 2150 cc/min. and a larger waste gate, but I'm out of $$$. So I will have to wait until next year for track times and dyno numbers.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
deanznz (11-04-2023)
