Old 09-27-2015, 12:35 AM   #306 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Originally Posted by pgfpro View Post
I personally don't like the idea of cylinder deactivation. I have it on my 2013 GMC and its a joke. I don't even use it anymore (run in manual mode) and have only seen a 1 mpg decrease with it disabled, but enough with my rant. lol
I also think if you deactivate two cylinders you will have some harmonics that will make the engine run very rough and also some intake flow issues. I did some C D testing on the Talon a few years ago and I couldn't improve on my fuel mileage, in fact my fuel mileage drop by 3 mpg.
I remember seeing your thread about excessive oil consumption with your truck. That seals the deal for me lol. You bring up a good point about intake flow. Everything is sized for a 2.0 I4. Dropping 2 cylinders for would make everything wayyy too big and flow would more than likely suffer.
On my sons turbo Civic 1.5 L it had a fairly large frame turbo on it based on the engine size and we still manage to improve fuel economy. I couldn't make any low boost lean burn though do to what we are talking about engine size verses boost. What I did is setup the car for lean burn with a max around 18:1 A/F ratio and the car got great fuel mileage. I think the compression was around 9.5:1?
I was reading your thread on d-series about your 64.8 mpg testing run that's what I want! Only better I will aim for reducing displacement through cam timing. My C.R. should be fine if you good with 9.5:1.
Were you running a Holset 351 off of a 5.9 Cummins on the Del Sol?
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following User Says Thank You to BabyDiesel For This Useful Post:
MobilOne (11-13-2015)
