Thread: EPA may fine VW
Old 09-28-2015, 02:15 PM   #64 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I had a question from a coworker. Has anyone seen a comparison of the current gen TDIs actual emissions vs the last generation? He is wondering how much worse 40 times EPA actually is vs the older engines.
In my opinion, no. The older engines surely made more NOX. A diesel that is tuned for power and efficiency has high combustion temperatures and makes NOX. Adding EGR reduces NOX and has been phased in over several generations of the turbo diesel. The latest TDI uses low pressure and a high pressure EGR circuits to further lower oxides of nitrogen or NOX. Some TDI owners have removed or eliminated EGR through a "tune" (off road only). This keeps sooty, hot, dirty exhaust gas from being run through the intake in which protects the longevity of the engine, makes more power and improves mpg.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
