Thread: EPA may fine VW
Old 09-28-2015, 04:29 PM   #67 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Sorry, I'm not sure if you're saying the current generation is putting more or less NOx emissions out than the previous generation.
Just edited to clarify. The current generation makes less NOX especially when tested on a front wheel dyno as done by the EPA. Evidently VW programmed the steering and wheel speed sensors to detect if it is on a real road or a "rolling road" as the British call it, to put itself into low NOX/run wimpy mode
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
