You need a certain amount of airflow to spool the turbine. VGT only goes so far in regards to that. The VGT turbo would be an interesting choice with the 2.0 setup, but the 1.0 just doesnt put enough energy into the turbine. BTW, if you get the VGT turbo that is canbus enabled, MS3 can address that and control the pitch angle of the vanes.
