Originally Posted by BabyDiesel
I read through your thread here and at d series, incredible! I really wish the boat tail would have been tested, it looked like a winner!
I have been thinking about turbos for the Escort. I decided that I wanted to keep it in the family though, so my first thought was a Garret GT3782 off of a 6.0 Powerstroke
Here are the stats from the ford-trucks forum.
compressor side:
IND whl = 59.10mm
EXD whl = 82.00mm
Trim = 52
A/R = 0.54
turbine side:
Whl dia = 72.50
Trim = 84
A/R = 1.12
Let me know if this is even a possible choice.
The converstation is everywhere Hardline! I am seeing that the asymmetric cam is the way to go. I will probably have to get a custom cam from Crower, but that is fine by me.
I will not cut and lifters either, that sounds scary! I wasn't going to do it, just joking around with a way to achieve what Russell (pgfpro) has.
In my opinion, the Turbine side of the 6.0 turbos is much to large to get a reasonable amount of spool, not to mention they weigh almost 40 lb's. There is also a GT3576VA that was on the VT365 International motors. The Turbine side on the GT3576VA is a bit smaller than the 6.0 version, but my feeling is that it is just too big. Remember it's not just airflow that drives a turbine, it's the expansion happening from the combustion. Expansion from the heat generated during combustion. When you're lean, you combustion temperatures will be lower and you will have more difficulty driving the turbine. When I was dreaming of turbos, I thought a VW TDI VNT turbo might be ideal. I don't imagine it would be hard to create a control for the VNT and they are quite small and have many aftermarket options. There is also the Dodge/Mercedes Sprinters that are a GT2056 VNT turbo if you want somthing a bit bigger...
