You're doing better in English than a lot of native speakers do, so don't worry about that.
Yes, our moderators are actually involved and vigilant. They have banned troublemakers, shut down a few pie fights, and generally keep the place moving along. That is VERY different from most forums I've visited.
The Corsa D should be able to do a LOT better than a mere 32 mpg. Either you have been flogging it - and by your own description that sounds unlikely - or there is something wrong. I suspect when you spend some time on the engine maintenance, you'll probably sort out a couple of problems you didn't even know you had.
Unless you have the Turbo?
